So I've been reading much on swapping out gears lately. I have an 87 JDM BJ74 auto, which I think is the A440F. The gearing on this tranny blows. Plus i'm running 31s and plan to put on 33s in the future. Right now, the gearing is gross. Overdrive kicks in at 65 km/h in the city and it bogs really bad.
Now I would like to, if the funds permitted, switch to a H55F, but theres no way I could afford it. So my other option is to re-gear the Cruiser. Now, if my math is right with smaller gears I can run bigger tires without the RPMs completely bogging down, correct?
And, if I do switch from 4.11s (Im pretty sure thats what my truck has, how do I check?) to 3.73s, is this just changing the gears in the diffs? Or is it tranny work?
Also, I've heard of some people running 3.08 Marks gears from John at Radd, that's quite a low ratio.
Info on switching gears and the mechanics would be great. Also, can I buy 3.73s new? How much? Can I find used? Where? How much?
Thanks boys.
TP
edit: I think my math is backwards. I need to go the other way in gear ratios to have better low and power right? And my 13BT is ugly sluggish in first. ANyone else with a 13BT auto and 31s have the same problem?
Thanks boys.
TP
