What’s your goal- stock ratio drivability with 33’s?
4.10 to 4.30 is less than 5% change and on the 5speed- not worth messing with- in fact mechanically speaking it’s prob a step backward if the front diff is the earlier weaker pinion. Also- the stock front diff carrier in all years is prone to flex under shock load- which can (and does) end in failure: ring gear on 5spd and spider on 4spd. Swapping the diffs won’t cure that weak point- (front diff) only a locked carrier will improve that.
Fwiw 4.88 isn’t “extreme” on a 5spd with 33’s but it’s going to chew a little more fuel. Transmission won’t work as hard either, and in mountainous areas 4.88 is awesome on long mountain pass climbs, but the cost again is a mission creep- cause if you regear, better to add the lockers while your at it (or double your labor later) and that’s going to add $2200 to your bill.
The suggestion for diff regear is a solid less costly option-that delivers a 4.56 gear ratio- but doesn’t solve the weak link which is the front diff. If you drive and wheel mindful of front wheel slip and shock load- you might avoid a ring gear fail.
