3FE Trans options..
Tonkota makes some good points. Years ago, my A440 shifted slow and sluggish. After I serviced the unit (fluid and filter) it was like a new trany and haven’t had a problem since…;)
Phil,
This is Jimmy, I have the white 80 modded from badlands just like your ORANGE trail modded FJ.
Give me a call sometime and I can talk about the A440F in detail.
I'll PM you my number.
Tighten up the kick down cable after you change the fluid and filter. That will make a huge difference in the way it shifts. If your A440 takes a dump you could opt for an extreme build from Rodney, or go the 5 speed route. I think those are your good options, manual or automatic. I don't know of a SMG that will work well in the Land Cruiser :D
after a kick down cable adjustment, my cruiser drives much much better... It even feels like it has more power but thats due to being in the right gear...
Mine has 258K miles on it and still going.. I think i'm gonna pull the pan and change the filter though
Flush it befor you change the filter the old filter will catch the deposits caused by the flush and the new fluid then drive it a week or so and then change your filter.
Cam
Ok folks sorry for the late update but I have to say...You all certainly rock!
We finally had a break in the weather and I was able to finally get under my 62 and do some of your suggestions. I read through various threads on the 3FE mailing list and followed their great instructions as well. I did the Governor Party Trick and then Rodney flushed the trans. I went through 3 gallons of ATF by the time all was said and done. It really didn't make a difference until I adjusted the throttle and kick-down cables. It feels like the 3FE finally woke up! I felt so good I gave it a basic tune up and now I can honestly say I love this big arsed truck!
A big thanks to all of you for your suggestions! You certainly make coming here worthwhile!
