- Joined
- Aug 26, 2007
- Threads
- 178
- Messages
- 1,036
I've recently put a 3FE in my 40 series truck. In the process I deleted the EGR and connected it to a H55F.
I was lurking on the Supra site where much work has been done on the 7MGE and 7MGTE ECUs. Apparently Toyota uses pull up/pull down resisters to tell the ECU processor if the vehicle has EGR or not and if has a manual or automatic transmission, at least on the late 80s 7MGE ECUs. Since the 3FE came out at the same time, I assume the design is similar.
There is a row of resistors R508 thru R502 in the 3FE ECU that tell the ECU if the truck has EGR and what trans it has (Inside red box in the picture). This ECU is for a US market truck that came with EGR and automatic transmission. I am trying to figure out how the resistors would be configured for a truck that came with no egr and/or a manual transmission from the factory.
Can someone with a 3FE ECU that came from the factory with a manual trans and no egr, if such a truck exists, tell us what resistors (R502 thru R508) are installed for that configuration. This, I would assume have to be a non US truck. Thanks very much.
