Someone needs to make these
What printed are you using ?
you do realize that many parts on the truck are already made of abs plastic. the grill for example is abs and it sees a lot of moisture and heat from the radiator and sun.
so far ive had only one failure, the customer didnt fully secure the piece and took it through a carwash which then destroyed it after it came loose.
in addition I recommend using a truck bedliner on them. weve all seen those commercials for linex recently, you can spray that stuff on water and it holds up.
