3B Voltage Regulator... (1 Viewer)
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
1984 BJ60, 12V
Ok. Replaced the diodes in the alternator about a year ago. Replaced the brushes as well. Also replaced the regulator (did reg & brushes before determining that it was diodes)
A few times over the past two months or so, my regulator has been over regulating - up to 16V at times. It wouldn't stay there, at idle it would be around 12.5, but at highway speeds it would sometimes go up as high as 16V - Not good for batteries or electronics.
So, I decided that before I toasted something, I would get a new regulator. Last one I got was from Toyota, at about $85CDN - it came as a Transpo IN218. It worked great for most of the year before it started doing this occasional over-regulate. Ordered the new one (from ASE supply online) Cost $38US shipped. Came as a Transpo IN218. Installed it last weekend and it seemed to be fine. Ran right about 13V - rock solid, Idle, full, anywhere in between. Yesterday It started not doing so well. Now I get 12V at idle, and maybe high 12's at anything above idle. (see pic for aproximate high)
So... did I just crap out and get a couple of dud regulators? or is there something causing my regulators to die that I am over looking? I don't want to just keep buying regulators if there is something else I should be looking at....
Thanks!
New Zealand
So... did I just crap out and get a couple of dud regulators?..
If your alternator was working hard, then I think "high 12's" may just be acceptable.
And the following may make your alternator "work hard":
  • A battery that is not fully-charged
  • A high current draw-off (headlights turned on or whatever)
So what I'm saying is that I wouldn't necessary assume your second solid-state regulator is faulty from those low voltage figures. (It depends!)
:cheers:
PS. Maybe leave your battery on a charger overnight and then do your voltage checks again without having anything like lights and heaters turned on. (See if you get a higher figure.)
MrMoMo
Ok, so an update on this... yesterday after work (noon), I keyed on to glow and only got about 7 volts. (DOH) boosted the truck from Moosecruisers truck and drove home with the only electrical load being the wipers (and any engine acc/gauges etc) The whole drive home was just over 12V. Now I know something is wrong here. - A bad regulator would not kill the batteries. So, I think AGAIN, I have lost a diode. To verify this, I put my amp clamp on the alternator feed line, and it was flowing 300 - 600 mA with the engine off - so that is what killed my batteries. To verify this, I pulled the alternator lead off, and it sparked when I disconnected it. There should be NO arc there, as power should not be able to flow from the batteries back through the alternator to ground - unless a diode is blown.
SO.. pulling the alternator off the parts truck this morning... WHY is it always the coldest day when I have to do this?? (yesterday was +7°C, today it's -18°C!!!!!)
So, I guess the question now, is if there was a diode that was on it's way out, could it have caused the old regulator to OVER regulate sometimes?
MrMoMo
If your alternator was working hard, then I think "high 12's" may just be acceptable. (See if you get a higher figure.)
I would agree, but I am getting low 12's with NO loads on - and it doesn't go up. (I see it as anything below 12.6, is not helping to charge the batteries - and I am below 12.6, no loads on) - I guess I may have mislead in my statement above. (that's why I put the picture up!!) Funny though, my charge light has not come on the whole time - so I guess the alternator is still putting out, just not what it should.
MrMoMo
Sounds like something else...
How are you batteries, connections, grounds etc. ?
~John
Well, I would think they are un-changed since the old regulator - but I guess it wouldn't hurt to check them as well. (though now I know something funky is going on internally) I'm thinking I have a blown diode on the positive side that is not allowing full charge to come out, and a blown diode on the negative side, which drains my batteries when the truck is not running. Dejavu a year ago...:bang:
Wherever the truck stops!!
I'm eager to hear the outcome. I have a similar issue with the FJ55 with the 3B. When I was having issues it seemed that the altenator had an internal short. Does that sound similar to your issues? An altenator guy here in Guatemala bandaided it but I want it right NOT "chapus" as they say here in Guatemala.
New Zealand
Ok, so an update on this... yesterday after work (noon), I keyed on to glow and only got about 7 volts. (DOH) boosted the truck from Moosecruisers truck and drove home with the only electrical load being the wipers (and any engine acc/gauges etc) The whole drive home was just over 12V. Now I know something is wrong here. - A bad regulator would not kill the batteries........
So you admit here that have flat/low batteries!
And, as I said before, I think that when batteries need a lot of charging - they impose a big load on the alternator. So in this situation you get high current-output from your alternator but at lower voltage than normal because of the "lower-opposition-to-current-flow" (lower resistance) produced by a flat battery.
....So, I think AGAIN, I have lost a diode. To verify this, I put my amp clamp on the alternator feed line, and it was flowing 300 - 600 mA with the engine off - so that is what killed my batteries. To verify this, I pulled the alternator lead off, and it sparked when I disconnected it. There should be NO arc there, as power should not be able to flow from the batteries back through the alternator to ground - unless a diode is blown.
SO.. pulling the alternator off the parts truck this morning... WHY is it always the coldest day when I have to do this?? (yesterday was +7°C, today it's -18°C!!!!!)....
You clearly know what you're doing and I agree with the steps you're taking.
So once you have a good alternator there (that isn't flattenning your batteries when your vehicle is sitting unused) - Hopefully everything will be fine.
PS.....If you have a battery charger, I'd recommend recharging your batteries to both "help your replacement alternator" and "provide more starting current in the cold weather you have there".
...So, I guess the question now, is if there was a diode that was on it's way out, could it have caused the old regulator to OVER regulate sometimes?
I don't really know but I would suspect that a regulator MUST be faulty (no matter what) to allow a "16V charge" to occur.
Good luck.
:cheers:
MrMoMo
Yep, I totally get that - originally the batteries were not dead though, that only happened on the last day. V = I x R so if I goes up and R stays the same V must go down. (more amp flow at same resistance causes voltage to drop)
Well I hope I do! - I've been through a bad diode a few times, and I could understand the regulator going bad, just was a bit confused by the 2nd regulator not fixing the problem. Maybe the first regulator over-regulating fried one of the diodes?
Man you know I hope so!!
Yep, I did that as soon as I disconnected the alternator, figured there was no point sitting around with dead batteries, and also no point in having the charger output drained to ground through the alternator.
Yup, that was my figuring too. It didn't do it all the time, so I'll keep it as an emergency back up.
Good luck.
:cheers:
Thanks! - Now if only I could get that stupid lower bolt out of the parts truck alternator!!! :bang::bang::bang:
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
