- Location
- United States
I have some parts I do not have a need for listed below. The parts are located in New Mexico and I am willing to ship if you pay the ride. I will try to get pictures loaded ASAP. If you request I will get them to you sooner. I may add more to the list as I find other parts I don't need so check back.
Used Turbo Manifold from an Isuzu Motor this is the same one I understand is being sold by others for $325.00 New to turbo the 3B. You will have to modify the top stude holes to make it work. I never got around to trying it myself. $75.00
New 3B water Pump, not sure what year 3b it fits, but willing to send pictures to make sure it will work for you. It was installed on a B Diesel once but was removed because the pully shaft was longer than the one needed for the B. It was never used. $65.00
I have a used shallow dish water pump pulley that came off a 3B. Once again I am unsure of the specific 3B model it was used on but I had it shipped from New Zealand if that helps. $25.00
New B Diesel Oil Pan Gasket, Gasket was purchased to fit a B diesel in a 1980 BJ40. Not sure if it will work on a 3B. $20.00
Used not working Voltage Regulator off of a 1980 BJ40 with a B Diesel. I had a hard time finding a replacement for it so I kept the old hopeing it could be repaired. Not Sure if that is possible. $15.00
Maybe more I will keep looking.
