wanting to learn a bit about the start/stop solenoid system on a LHD 1982 BJ42. I held the plunger over manually & it fired right up. Referred to some posts here, but was unable to locate the EDIC relay….I did see a few others but need some schooling on where I might find it. I did note a “28610-54180 Glow Plug Relay“ near the LH headlight, also a “28300-56010 Starter Relay” & a “28521-57010 Timer, Pre-Heating Relay” under the passenger footwell but could not locate a relay with the words EDIC…any assistance welcome. I was expecting to see a relay marked EDIC however that did not happen. On the drivers side I noted a flasher relay & a headlight relay. This BJ42 drive train will likely be going in a 1977 FJ45 eventually, but would like to get iany issues sorted before I pull it out of the donor BJ42. The 42 has a 24v warn winch so was leaning towards keeping it a 24v swapover. i definitely need some schooling on Landcruisers tho self admittedly.
