If I'm not on the floor I would never get out of first gear. I'm wondering if there is something wrong with my accelerator linkage...??
A BJ60 is not supposed to be like that amigo.
My Bj60 only needs to be breathed on for acceleration. It's only the 60 kph to 100 that is sluggish. The bottom end jumps right up and thru the gears with next to nothing for gas pedal pressure.
If I was you here is where I would look first.
- take the tube off the intake at the butterfly. have someone start to push the throttle(engine off) watch the butterfly. See that it starts to move right away, also see that it goes fully to open when your foot is all the way down.
-next have a really good look at the tubes that go down to the injection pump governor see that there is no cracks or holes. visually. They control the pump thru differential pressure.
-next if you have no clue as to when the diaphragm has been replaced in it's 23 yrs of service, just replace it. It's the main control mechanism from the butterfly.
If your injectors have not been serviced(removed and replaced with serviced ones) then plan on doing so.,
Also your injection pump may not be timed ideally. Which you can do, but I would be inclined to let a diesel injection shop do, with the nozzles too.
If you have to floor it to move the truck there is a problem.
