35's and axle/clutch damage
GMSilk_Fj60
Central MD
i have a chance to get sum new 35's cheap but a friend of mine tells me landcruiser axles cant push em`. I no my motor can being performance, but is the clutch up to it? axles? I see a centerforce in the future no matter what but?...
Dacula, GA
Your landcruiser axles are just fine with 35s, i have 35s locked in the rear in cruiser axles and have never had a problem...and everyone else i know with 35s have cruiser axles....KEEP EM and go with the 35s
Nick
Colorado Springs, CO
Yes you will be fine.
How are you geared? Stock gearing will probably suck with 35's. I am running 4.11's and that leaves a lot to be desired. You probably will burn a lot of clutch off road, but you won't destroy it, just wear it a lot faster. And an OEM clutch will do just fine, no need for some Non-Toyota centerforce clutch ;)
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
lowtideride said:
with longs you could run friggin 40s....kick your friend in the nuts.
If you do that to your friends what do you do to your enemies????
:flipoff2:
I've just about wornout my first set of 35's.....
( DD and offroad)
No clutch problem and NO problem with the axles !
Yes, I've 4.11s
Bostonfj60
USA
I have 35's on my FJ60, with stock axles/clutch. I did however re-gear to 4.11's.
If you get a front locker, you'll want to swap out the stock inners with a set of Longfields.
(thats my plan)
JR
valencia, Venezuela
one question: i'm planning on going for some 35's and with 35's what gears would take me back to stock relation? cause some of you said that with 4.88 you lose overdrive and i woudn't like to lose any cause i do a lot of highway
Bostonfj60
USA
4.11's, assuming you have an H42 4spd tranny
My spedo is almost dead-accurate again. with 35's, and 4.11s'
You can try to find a set of complete 3rd members from an FJ62. They'll pop right in.
If you're interested, email Kina at northcountrylandcruisers@yahoo.com I think he's got some 4.11 3rd members.
JR
t town, wa
how much lift you need to run those 35's. i was thinking of just going 33 but decided fawk that. if i have to lift and get new tires anyways, i should get what i want
Tapage
Club 4X4 Panamá
Panamá
I thought the better gears for 35" are 4.56 .. with stock engine ..
Dacula, GA
If you wanna run 35s, a good lift to go with (I have it) is the Man-A-Fre shackle reversal with the HABU lift springs and U-bolt flip kit...all together it is about 5 in. of lift. 35s look great on it
Nick
t town, wa
Nick
sweet thanks man. brake/steering ext.?
valencia, Venezuela
that's what i'm planning but i want the 4" OME kit from MAF.
and i think i'm probably going with some 4.56's that could get me right back to the stock relation
Dacula, GA
The kit i got came with extended stainless steel brake lines...i havent done anything to my steering as of yet, but i am either going to get the 4x4 labs steering system or go with hy-steer
Nick
