3 speed column (1 Viewer)
Georgia
I have a 71 fj40 and recently the shifter is coming out of the steering column. Seems to be threaded? Just curious if im overlooking something before I do something rash.
See my pic from microfiche. The shift shaft is held by two spring controlled pins. Check there first. Push both pins at the same time.
The search function works pretty good, either here or on the internet. Any result that references this site. There are many more threads than this one link. I'm sure it's been covered on this site.
Also, find an early FSM to download.
33513 just threads into the column signal collar but is not threaded in tight-I think it's supposed to have a little movement. I have found mine rotates when shifting so I just slapped a thick coat of antiseize on the threads and it hasn't unthreaded in 4+ years
