Alright, so here goes. I have an auxiliary fuel tank on my 40 and it suddenly stopped working after I left the switch it on accidentally one evening. I crawled underneath it and discovered the previous owner installed a pollak 3 port fuel selector valve. This is a very reliable and common set up. I figured I burned it up by leaving it on all night, so I bought a new one and replaced it.
I simply replaced the three hoses I removed in the exact same ports and hooked up the hot wire. NOTHING, Nada. I check the connection to the hot wire. It is good when the switch is activated. But fuel is not being moved from the auxiliary tank to the main tank.
Any suggestions on where to start? Prior to hooking up the new selector valve, I hooked it up to the positive and negative terminal and the selector valve was working, just not continuously. It would just click intermittently.
