2UZ VVTI o-ring replacement warning/ P0012 P0022
Texas
This is probably the best place to post this since there's not a ton of information out there on replacing these. Hopefully the tundra/sequoia people know how to use google. This is just for people getting a P0012/P0022 after changing their o-rings.
If you're replacing the cam seals there's no reason to not replace the o-ring, especially with how old these engines are getting. Both mine were rock hard at 226k.
FSM calls for replacing the entire VVTI assembly (13050-50021). I bought a pack of 5 o-rings (1288N363) from McMaster-carr for $22 total. You'll also need a T30 tamperproof torx plus bit to remove the VVTI cap.
For those who haven't replaced them:
Both youtube videos only mark where the VVTI cap aligns to the VVTI assembly. You also need to mark the positions of each bolt on the cap. The caps holes that the bolts pass through allow the cap to just slightly clock itself a couple degrees back and forth. If it's reassembled just slightly off you run the chance of causing a CEL.
Once apart it's pretty simple/easy to replace the o-ring with the entire VVTI assembly removed. The cap and innards came apart as one with a couple love taps. Reassemble as it came apart, I torqued the 4 torx bolts to 72 inlbs.
For those who now have a P0012 or P0022 (or both) after replacing them:
I got both codes after my first startup. After originally clearing them thankfully my P0022 went away but my P0012 remained.
There's basically 3 things associated with this code: The solenoid, filter, and VVTI assembly.
The solenoid is easily tested. You can pull it and directly give it power to see if it's actuating correctly. In my case with the P0012 powering it directly with the engine running did not change anything. I could hear it actuating but there was no difference in engine noise. Which sent me to check the oil pressure going to the VVTI assembly: Depending on how much FIPG was used there's a chance that the filter is clogged and not enough oil is getting to the VVTI assembly. I removed the belt again (can't just remove the cam gear cap, at least on bank 1). My filter was not clogged and this was an awesome way to waste 4 hours.
This is where I remember that there's a couple degrees of play with the VVTI cap to the assembly. Luckily this can be adjusted on the car with the timing belt and everything still on.
I loosened the 4 torx bolts just enough that I could rotate the cap back/forth by using a 19mm wrench on the washer bolt (not in this picture).
First I clocked mine all the way counterclockwise. Tightened the torx back up to 72inlbs and tested it. At idle now the VVTI assembly had a "slap" noise that would go away when it was given oil pressure from the solenoid. Loosened the bolts again and clocked the cap all the way clockwise this time. No slap noise at idle, and now when directly powering the solenoid I could hear the VVTI actuating. Took it on a test drive and confirmed I have my VVTI power back.
So this fixed my P0012. I think these assemblies are sensitive enough that they need to come back together exactly as the came apart.
Good suggestion, marking position.
Can I ask.
Did you find evidence. "Oil" was passing/leaking from O-ring(s)?
Are you seeing other oil leaks i.e. front and rear mains, VVT solenoid actuator, oil cooler & filter housing. etc..?
Any "High Mileage" oil used?
Any overheating events, generally ran hot (over 200F), clogged radiator fins, low coolant level, coolant leak(s), radiator R&R?
Can I ask.
I recently bought it so can't really speak on the history. The radiator was replaced.
From the first pic you can see the oil leak on the far right of the cam gear cover. It was bad enough that it was dripping down onto the AC compressor and then to the oil filter. Thought it was the oil cooler o-ring at first until I really tore it down.
My cams seals were still decently soft. The VVTI o-rings were basically plastic. I had to chip the bank 1 o-ring out in little chunks, it was that hard. Also the inside of both cam sprockets were oily. Not sure if the cam seals can do that.
Well, I’m one of those people.
I have an 06 Tundra with a cam seal leak. I’m debating if I want to mess with changing the vvti gear o-rings. My leak clearly seems to be coming from BEHIND the cam. To my understanding, if it’s behind the cam, it’s cam seals. If there’s oil inside the cam gear and on cam cap face, then it’s the VVTI gear o-ring,
I’m from over on “Tundras.com”, the idea of replacing the timing tube o-ring on that forum is very rare and has only been mentioned once or twice and people immediately dismiss the idea of doing it. That’s why I’m a bit hesitant to even mess with it. It was mentioned once on a facebook group and also immediately dismissed.
Here’s some pictures of my leak.
These are my orginal pictures after discovering the leak. I did timing belt a year ago and it was dry then. I’m assuming it started shortly after that and I didn’t notice it until a few months ago changing my oil and seeing a wet compressor. I believe it’s a slow leak. I’ve since cleaned the area and added AT-205. It didn’t completely stop the leak, but it seems to have slowed it.
Here’s my plan
-If the inside of the cam gear is DRY, LEAVE IT ALONE
-If it’s wet, order the o-rings and replace
Just looking for some reassurance here with my plan as the guys on the tundras forum are not as familiar with the vvti o-ring. Do you guys think it’s cam seal or potentially the vvti o-ring? I’d really like to not mess with it. It seems like a lot of people who have touched it has caused problems and codes.
Idk why, but it seems like with the gx470 it’s more common. Maybe it’s because gx470 had vvti from 05-09 and first gen tundra only had it from 05-06, so there’s a larger sample size for gx470?
Here’s my plan
I had that exact leak that traveled down the compressor onto the oil filter. There's also a chance it's the cap that covers the camshaft gears/seals leaking too. Probably original FIPG there.
If it like this, that means it’s cam seals?
If it looks like this, that means it’s o-ring?
The inside of my cam gears were both covered in oil like that too, yeah. Hard to tell if it's the o-ring or the cam seal with that one.
Like I'd mentioned before, my cam seals were still soft. The o-ring was basically plastic. If I had to guess which one was leaking, I'd immediately suspect the o-ring. You can change the o-ring with the timing belt and everything still on but it's definitely more annoying.
Here's the videos I found useful:
Yeah I’m thinking it might be a combination of the original FIPG failing and the cam seal.
Yup, I’ve seen both of those. Good videos. I also saw your comment on that one guys about this solution for the p0012/p0022.
Did you have a significant amount of oil behind the cam gear like I did?
I also saw this video. Ngl, the guy seems like a bit of a hack. But he shows it being done outside the vehicle without all the tiny little pieces falling out.
I think I’ll just buy the o-rings in case. But if it appears they are dry I won’t mess with it. That video I linked in the first person with a sequoia/tundra i’ve seen mess with it. Still kinda confused on why it’s so rare on the Tundras.
Appreciate the reply.
