Does anybody know of any good options for a 2nd battery tray other than Slee? I was set to order the one from Slee, but don't need the compressor mount and would like to be able to go with a bigger battery than the Slee tray allows.
That looks like it would be perfect for my needs, unfortunately it doesn't look like it's available in the US.I have the Piranha one, not sure if you can get that in the US?
Thank you, you've confirmed my concern with the new version from Slee. It would be nice if they could offer both versions, but I did check with them and was told they no longer offer the old version. The search continues, thanks for the help from both of you.I just picked up the redesigned tray from Slee a few weeks ago. I also have no need for a compressor in that location, but being that I had to get my second battery in right away, I ordered it soon after it became available. The compressor mount leaves little room for a good sized battery. (I want to support a referigerator and other 12volt things for several days at a time) It's only a tiny battery that this bracket was built to support. I just thought it would be nice (and logical) to have the choice of a larger battery over the compressor mount. (two different part#'s) ...Just my thoughts.
Do you have any photos of your install? Wondering if it's possible to modify the tray to allow a larger battery if the compressor isn't mounted?I just picked up the redesigned tray from Slee a few weeks ago. I also have no need for a compressor in that location, but being that I had to get my second battery in right away, I ordered it soon after it became available. The compressor mount leaves little room for a good sized battery. (I want to support a referigerator and other 12volt things for several days at a time) It's only a tiny battery that this bracket was built to support. I just thought it would be nice (and logical) to have the choice of a larger battery over the compressor mount. (two different part#'s) ...Just my thoughts.
I just replaced my non-compressor mount Slee with the new compressor mount version and was about to list it in the classifieds.....I need to look back at what size it is capable of holding...
The new 2nd battery tray and compressor mount was developed since most people that we deal with puts lockers in and also 2nd battery system. We are limited in space and it took quite a bit of finagling to get all that in the space we had. The battery we designed it around is the Interstate MT7-75DT. So any battery of that size would work.The original battery tray we made was for an Optima Red Top. People stuck larger batteries into the tray, but we did not support it as such.
If you really want your aux battery to be the larger group 31, the easiest would probably be to swap the functionality of the batteries. Use an isolated battery post and attached all the vehicle wiring that normally goes to the starting battery to that, then run a large battery cable over to the 2nd battery. So now you use the 2nd battery only as starting, then use the group 31 upgrade tray and large battery and designate that one as the house / aux battery. Little bit of extra wiring, but not that complicated.
Thanks for confirming this. I thought that it was ok for AGM batteries to be operated on their side, but couldn't find where anybody on this site had done it. The batteries plus site also says it can be operated on it's side, so I should be good to go! Thanks to all for the replies and advice.Great idea! There's zero problem operating an SLA or AGM battery on its side.
You guys got a square airbox, interesting.
Finally something we have that you guys want.![]()
