Hi guys,
Just trying to figure out why my second battery decided to boil out is acid …
So a little back ground, the car is a 88 HJ75 with Trekker conversion, it’s a 12v car with a second aux battery installed. The main is a new 72amp and the Aux is a 2 year old 70amp… it happened after 3 long drives of around 1500 kms … the car wouldn’t start one morning, so I flipped the hood to see the aux battery inflated and spewing acid.
I disconnected the battery and after a few tries she started, completed the holiday on 1 battery no problems… the additional volt meter shows a comfortable 13 Volt at all times including when the fridge is connected. Maybe a little less on tick over to be expected….
I thought it’s the battery regulator that’s the problem, but was told its more likely either a duff batter or the alternator on the car…
I still need to connect a aux battery and check the voltage with the engine running…anything else I can check to find its cause..
Cheers
Matt
