Mounted the radio above the rear view mirror. No problem with visibility of the road, mirror or radio. It pivots on a center bolt so it can be aimed at driver or passenger. A little velcro on one side of the mike cable and a cheap sunglass clip secure the mike cord while still allowing quick release.
I used the existing holes on the mirror mount to secure a stiff piece of metal for the bracket. I stuck a block and some foam (wrapped in duck tape) to force the angle down a bit giving me a straight on view of the screen - which helps with the LCD. I even used the visor screws to attached a couple cable stays. Didn't have to drill any holes or make any "permanent" changes. Not that I care. I did drill a hole in the roof for the antenna.
I may clean it up a bit, but it's solid and working great so far.
