Have a 2L powered 4Runner. Someone is selling a 3B near me that needs a rebuild (200psi on one cylinder). Will the 3B bolt up to the L series bellhousing? Worth the swap? I know anything is better then a 2L.
At 500 bucks I would buy it for fun. Where are you located?Hmm okay thanks for the quick responses guys! Hearing this I might pass on the motor. He wants $500 for it and I don’t even know where to go for rebuild parts. I’ll stick with the 2L a little longer. It’s running in the low 300s for cylinder pressure so I know it’s pretty worn and tired too. I’ve been looking at those OM617 swaps too.
Okay do you have a link to the ad? I live in Kelowna area and need 3B parts.Hmm okay thanks for the quick responses guys! Hearing this I might pass on the motor. He wants $500 for it and I don’t even know where to go for rebuild parts. I’ll stick with the 2L a little longer. It’s running in the low 300s for cylinder pressure so I know it’s pretty worn and tired too. I’ve been looking at those OM617 swaps too.
It’s in peachland, close enough though lol. Cool to have a fellow Kelowna person here. Know anyone with L series parts? LolOkay do you have a link to the ad? I live in Kelowna area and need 3B parts.
WordI own vehicles with both engines. It's not worth the effort to try to convert the 2L to a 3B. (I converted my HJ45 Troopy from an H to a 3B and the amount of effort was not really worth it. If I didn't already own the 3B I would have installed a V8.) The entire drivetrain would require modification. The 2L transmission does not bolt up to the 3B and I doubt a reasonable adapter could be fabricated. If you decide to install a transmission that's compatible with a 3B you will need to change your rear axle too. h42/55 transmissions + tcase have offset rear diffs. The transmissions behind the 2L have a center diff in the rear. It's not worth the aggravation. A newer engine in the L series will be a lot easier.
