this is a (rusty) edic relay from a 12V HJ60.
Jan
Jan, that looks EXACTLY like what I have. Do you have a wire pin out on that so we can compare. It looks like the part number you have is about as easy to read as the one I have.
The wires on the one I have, starting with the yellow on you can see clearly in your picture are as follows:
Yellow, Green/Black stripe, Red/Black stripe, White/Black stripe/brown dash, Yellow/Black stripe/brown dash, Black/Yellow stripe brown dash the first four are "medium gauge" wire, the last three are light gauge that is it for that row.
Next row is as follows:
blank, black heavy gauge, Blue/black stripe, gap for latch, blank, Black/white stripe, blank the last two wires are light gauge.
Let me know if that is the same as yours. No guarantee that this relay works.
We are currently searching part numbers. We considered putting in a "wilson" switch to power 10.5v glow plugs, however we realized that if he were to replace them in Liberia they would most likely put in the stock 8.5v plugs.
Therefore we are now looking for a part number for a 12v non-superglow glow plug timer. Can anyone help us out?
Thanks
Leni
Are you sure the non-Superglow plugs are only 8.5v? My FJ55 with the '81 BJ60 non-Superglow wiring harness and relays runs 10.5v plugs. The '82 BJ60 with the Superglow system runs 6.5v plugs.
Are you SURE he cannot get 10.5v glow plugs in Liberia? I haven't been to Africa yet but in Guatemala we could get most anything if you knew where to look.
