2F valve springs are stacking!
I'm about to drop my freshly rebuilt 2F into the 60. After cold adjusting the valves this morning I was turning the motor over by hand (socket on the crank pulley) and they cycles got way too stiff. I noticed the valve springs were becoming compressed beyond their limits. Here are some specs of the rebuild related to the head/valve train:
cam reground to Mark W specs (similar to MAF rv grind)
head shaved 80 thousandths
newer stock springs shimmed to achieve correct installed load
I can turn the motor completely over with effort, but I think it's too tight. My gut tells me this could be very bad for the valve train, am I correct? I guess a few options would be too remove the shims and settle for less spring pressure, or install new heavy duty springs (sbc chevy springs?). Yeah I was looking for more compression, but not this much! Any suggestions?
