2F Propane (LPG) Conversion with an Impco 425
Cary, NC
Hey All,
Just finished up my LPG conversion on my '78 FJ40. I am sure some of you have seen some threads I have posted for help, but I thought I'd start my writeup. I still have some tuning to do since I am getting horrible mileage - I think I really need to get my dizzy recurved and I have to get an AFR setup to find out where I am on mixture. I'll add that to this writeup as I get that done.
My main concern was that I was getting some carb stumble out of my 38/38 Weber, which had previously served me really well. I never could seem to get the mixture right and since my Cruiser "Dozer", is mostly a trailer queen, I decided an LPG conversion was a good option. I looked at doing the 2FE, but have domed pistons so I scrapped that idea.
I started off by buying a "kit" from a fellow Mud member. It included an Impco 425 mixer, Model E evaporator, vacuum lockoff, fuel pump blockoff plate, heater hose taps, vapor hose, and a Offenhauser dual-plane intake, as well as a Holley (650?) vacuum secondary throttle plate. I picked this up for $400 and added the high pressure hose for $68 from Nash Lift Truck Supply Co. - Clark Forklift Parts, Caterpillar Forklift Parts, Hyster Forklift Parts, Yale Forklift Parts, Baker-Linde Forklift Parts, Intrupa Forklift Parts, Clark Lift Truck Parts, Caterpillar Lift Truck Parts, Hyster Lift Truck Par - Bill is topnotch and I highly recommend them for any LPG parts!
First, I utilized the bottom portion of my 2F aircleaner assembly to mount the Model E and lockoff. I simply drilled two holes to match the mounting pattern of the evaporator and tacked two bolt from the bottom to act as "studs". I cut off the "intake portion of the aircleaner to make room for the vapor hose to run from the evaporator to the mixer.
Next came plumbing the evaporator. You simply have to tap the supply and return lines from the heater with supplied Y-Pipes. They can be seen here:
Supply:
Return:
You have to make sure to install the y-pipes in the same orientation so that one is pumping coolant to the evaporator and the other is sucking it out and back to the radiator. This warms the Model E to help convert the LPG to vapor form.
I connected the high pressure hose to the lockoff and routed it directly down the firewall on the passenger side of the transmission and up into the cap where the fuel supply and return hoses originally were located:
The tanks are to be mounted in the rear, one on each fender well - brackets are on order and I'll update the thread once I have them installed.
Next was fitting the Offy intake. I am running 3FE exhaust manifolds, because the 6-1 header I ran for years never seemed to make a good seal. I had to rework the mounting surfaces to make sure the flange thickness was identical between the intake and exhaust manifolds. I simply used a dial caliper and filed the aluminum intake until each bolt location had matching thicknesses. I also used copper washers on the studs in the center locations to add some forgiveness since the copper molds when you torque the nuts down good. They can be seen in the picture below (barely), but the next picture is more to show the bracket I fabbed to maintain the stock throttle linkage:
The Holley four barrel base plate bolts directly to the Impco 425 and the Offy intake. It utilizes vacuum secondaries, which apparently won't work with LPG, so I tied the secondary linkage to the primary using a machine screw and nut. You can use this to adjust how far in the throttle cycle the sencodaries open, which I have moved since this picture:
I wasn't sure if it was necessary, but I filled the vacuum ports on the baseplate with JB Weld and sanded smooth. I believe the key is to close up the hole in the center of the plate, but I knew the other ports weren't utilized with the LPG mixer, so I filled them as well. I left one vacuum port open, which is to be utilized for dizzy vacuum advance:
Next issue was getting the throttle linkage to work with the Holley plate. I looked at getting a cable pedal setup, but decided that was more trouble and an extra $150 - plus I think the stock linkage is a good setup. So I had to manipulate the linkages to fit the Holley throttle linkage location. I had to shorten the throw rod that goes from the firewall bracket to the carb. I fabricated an L bracket to mount the throw rod and it can be seen in the photo above I included to show the copper washers. I also had to cut and reweld the bracket that mounts to the firewall about 1 inch towards the passenger side to get the linakges to match up. I robbed the linkage ball joint from my Weber that mates with the Toyota linkage and mounted it to the Holley arm. I also had to trim the Holley baseplate arm because it was hitting the brake booseter. A few pics of the linkage mods:
Next I just had to mount the 425 to the Holley baseplate. For this, I couldn't find the exact right gasket, so I used a generic Holley baseplate gasket and trimmed it to fit the 425 (between the mixer and baseplate).
The next issue I had was the aircleaner. The Impco 425 has a 5 1/8" diameter neck, so most Holley open air element assemblies will work. However, given the close proximity of the mixer to the brake booster, there is no room for that style. Therefore, I found this "trick" Spectre 9841 Carb Hat/Plenum. It was about $80, but it's the best I could come up with that would fit in the space left. I used a Spectre open air intake element I got on the ricer isle at Autozone for $25. One issue was the valve cover vent connection. I drilled and tapped the plenum to accept a brass NPT 5/8" hose barb and sealed it with some silicone:
The last issue was getting manifold vacuum for the PCV. The Offy I got had a huge threaded port on the side that was tapped for 3/4" fine threads. I couldn't find any manifold union to fit that port, so I had to make one. I center drilled a 3/4" bolt and tapped it for a 1/8" NPT hose barb:
:beer: Ramon
That is nice, as soon as my tax return arrives I plan on spending the money and purchasing a "got propane" kit. He builds a model that bolts onto any Weber conversion plate and it is all inclusive (I simply don't have time to source all of the parts I need).
I'm excited to park the 62 and drive the 40 a bit on the trails as it has been years since I really operated it.
You'll have to let us know what if any tuning issues you have.
Dan
First trail run :)
Got my first trail run in on LP Saturday and was VERY happy. Purred like a kitten at any angle. Was only out for about 2 1/2 hours, and burned about 2.5 gal. That''ll work for me as I can run a full day on one tank.
:beer: R
Awesome, that is what I love hearing.
Also, Your 40 just has the right "look" to it, really dig it.
I have an Im425 I got with a manifold off ebay and want to try seting it up in a '78 2F in my FJ40. Local fork lift dealers have the hoses and the tanks. I hope I did not make a mistake buying this part and to see your good work is encouraging!
I'm interested in setting a system up for my Land Rover S-1 and S-3 which use Solex carburators now.
Please continue with your educational thread.
Really not a whole lot more to report snakedog. She's been running great since the conversion. The power is down midband, and I only get 8 or so mpg for street driving on LPG.
However, right now the head is at the machine shop getting .090 shaved off and a valve job. I'll report how that wakes her up and hopefully, increases efficiency. Later I'll send the dizzy off to Jim for a recurve to better suit the 'pane.
Bottom line, great convo for the rocks, but it's a pain getting 'pane. Luckily I have an Ace that refills right by my house, but it's not cheap. Also, you have to plan your tail rides, because you can't just pop over to the Shell station and top off in most towns.
:beer: R
I just got my kit and I'm in the midst of the install. I'm gonna need to go with the Weber cable because the linkage will not work without an engineering degree on my setup.
I have researched propane and happily they have a refill center in Moab and one down the street from my home in SLC at 2.10 a gallon.
I guess there is an advantage to trailering the rig when it come's to propane.
Thanks Ramon Weller;
Have you gotten that head back on and everything running right?
In the UK lots of Range Rovers, Defenders and series Land Rovers have been converted sucessfully to LPG as they face $15.00/gallon fuel costs on gas. I get good reports on fuel economy as long as there is no duel fuel arrangement done. They fuel up at their home LPG tank and carry cannisters with them or long hauls. It's the new thing in Australia as well. Locally the school buses and metro busses run on LPG engineered systems. At least Toyota has the same moter on their forklift product as the FJ 40.
With the winter over I still have the FJ intake manifold with the LPG kit installed sitting by itself uninstalled on anything. The unit sits on the shelf. I'm considering selling it.
I'm in the process of installing a 2F in a '79 FJ 40 after removing the current Chevy V-8(clogged by rodent fluff at flywheel housing). Anyone interested in my LPG conversion unit please let me know.
Snakedog
