- Joined
- Dec 20, 2007
- Threads
- 131
- Messages
- 1,123
- Location
- Orcas Island in NW Washington State
- Website
- www.mtpickettwoodworking.com
When I finally 'caught threads' on that bolt it was pretty much the 'second best feeling EVER'.......
Having this same problem. two questions: 1.) what do you mean by drop torque values 15%? for the bolts vs studs or what?I did drop the down pipe once, and it made it easier. Just remove the bracket that's attached to the bellhousing, or around there, and it'll drop down. But those bolts are prolly rusted to hell, so that might open new issues. Helps to have a second set of hands to pull down on the down pipe, if it's still all attached.
Sure you can reuse the bolts, nuts. Prolly 99 percent do. Just clean 'em up and use some good, hi-temp anti-seize and drop the torque values about 15%. The stud kit works, I've used it, with the head on the engine... it just takes some finagling to get the manifold to fit. And it also improves your cuss vocabulary, too!
Good luck.
When anti-seize grease is applied to any fastener’s threads, the designated tightening torque should be reduced by about 15% to account for the reduced friction.Having this same problem. two questions: 1.) what do you mean by drop torque values 15%? for the bolts vs studs or what
