Wanted 2f double crank pulley and power steering lines
@SW20 just reminded me two weeks ago that as a result of a collaborative effort he was involved in, you can purchase the cooler line from Classic Tube. @Spike Strip just posted up last week a source for the high pressure hose.
If you have a US shipping address, I may be able to help with the pulley.
if the OP is in NZ, not sure the US stuff will work with a RHD, the cooler line would need to be a mirror image of the US version.
the preasure line should? work if the pump is mounted on the right side of the block
good point Paul. His avatar is a Non US LHD cab, if that means anything.
