2F Distributor Breaker Plate Binding - Successful Repair with New NipponDenso Parts
4Cruisers
During the refurbishment of a '77 2F vacuum advance distributor I wasn't able to get the breaker plate to rotate smoothly, no matter how much I cleaned and lubricated it, so I was almost ready to give up on the distributor. I decided to disassemble and clean the breaker plate assembly to inspect the parts. It's pretty easy once you learn the trick to remove the four small spring steel clips. There is a two-piece race that holds 50 small ball bearings. The two race halves are held together with the four small spring steel clips. The rotating breaker plate rides inside the race on the ball bearings, it has a U-shaped groove around the outside perimeter that captures the ball bearings. I noticed a lot of galling on the inner surfaces of both race halves - circular depressions from the ball bearings all around the inside perimeter. The ball bearings hang up in the depressions as the plate rotates, which is the cause of the binding. However, the U-shaped groove on the rotating part of the breaker plate was still smooth.
New breaker plate assemblies for the 1/75 through 9/77 distributors are still available from Toyota, but the retail price is $79.53. I decided to look into new parts from other NipponDenso non-Land Cruiser distributors. After comparing dimensions I removed a breaker plate from one of the new Toyota parts distributors in my stash and disassembled it. After disassembly I cleaned the factory applied grease from the parts. The rotating part of the 2F breaker plate fit right in the two-piece race - it turns out the race and ball bearings are common to both distributors (a common Toyota practice). Then I reassembled the breaker plate assembly using fresh distributor grease in the U-shaped groove to hold the new ball bearings in place while I sandwiched the rotating part of the plate in between the two race halves. Then I installed the four new spring steel clips to hold the assembly together, and checked it out. The 2F breaker plate rotated as smooth as silk, so I installed it in the refurbished distributor.
Given that success, I compared the breaker plate assemblies with the later 2F electronic distributors - 9/77 through 7/80 and 8/80 through 8/87. Apparently Toyota changed the two piece race with the electronic distributors, so this kit won't work with them. However, the ball bearings aren the same.
It's really easy to remove the old breaker plate assembly from your distributor, disassemble it, swap out parts, reassemble, and reinstall in your distributor. Once your distributor is out, you should be able to finish the job in less than an hour. While you've got the breaker plate out, it would be a good time to replace the mechanical advance stop pin bushing if needed.
I have more than 20 breaker plate repair kits, and will be posting them in the For Sale forum. The kits include the two race halves, the 50 ball bearings, the four clips, and new hardware to secure the breaker plate assembly to the distributor housing.
This is outstanding. As you know I recently went through trying to free my poorly moving breaker plate. Got it free and moving again but it still is not perfect. Having gone through this recently I can attest to how valuable this fix is. Great there is a kit available to properly refurbish these now. Thanks for this!!!
