Moby
GOLD Star
I know that a 2FE can be built by combining a 2F short block and a 3FE head. I'm wondering if anyone has looked at the possibility of stroking a 3FE short block by using a 2F crank to gain more stroke than can be had by offset grinding the 3FE crank.
Let's assume that custom pistons, rods or both would be needed to get the piston height correct at TDC in the 3FE block and that block clearancing for the longer stroke would also be needed. How about other potential issues like the bearings and caps, front and rear seals, oil pump/pickup interference, timing gears, front cover issues... Anyone know of anything that would make this a no go?
Why go through this trouble? I doubt a 2F block under my 3FE head would pass a visual smog inspection and I'd like to gain as much displacement as possible if I'm going to rebuild my 3FE.
