Wanted 2F cam thrust plate, fuel fitler holder bracket
delaware ohio
Website
www.facebook.com
  1. 40 Series
  2. 55 Series
  3. 60 Series
Just looking for cam thrust plate and fuel filter support now. id rather run a good used one then the SOR.
fuel filter support seems to be not sure if an fj60 fuel filter support would work. part number i found was
23921-61031
I have a timing cover plate, new cam gear and a cam thrust plate, as well as the screws.
I see that you have a separate ad for a 3groove HB. That makes it worth noting that the timing cover plate changed near the end of the 2F run, and if your engine is one of those, you will need that specific plate.
Don’t have the nozzle or screws, but have these parts.
You may not need the woodruff key or the crank oil slinger. Those parts were just all together, so took a pic of the lot.
@65swb45
this is the timing cover that came off the motor, pretty beat up too. id rather get one in better shape. do you have a plate that will fit?
still looking
@CruiserTrash sells A reproduction oiler nozzle.
SOR sells a repop cam thrust plate.
Can't you get the rest of it from Mark's Off road? Most likely the timing plate will come with a nozzle
Thanks for the mention Alf. We talked. I can’t find my box of timing covers at the moment, and I don’t have the wherewithal to pull one off a long block at the moment.☹️
all parts need to be good, flat and not bent.
23921-61031
i have 2 matching sets / pairs of OEM Toyota Genuine Parts Timing Gears ...............
i also offer both OIL PUMP pick-up tubes / pipes compression nuts to main oil pump body & main engine block oil galley in-ward Female threaded port
F
1.5 2F 3F Carb 3-FE Engine Application's
still looking
Hey man, I see lots of people jumping in here so I’ll keep it brief. I have brand new oil nozzle reproductions. You can find them here.
Other things I have:
Timing cover, decent shape
Matched set of timing gears in good shape
Serviceable timing plate
All of those came off a 60 Series 2F if it matters.
