SOLD 2f Aisan carb
Western, SD
Came out of a 77 FJ40 with low miles. The fuel cut off silenoid connector was cut off to adapt to trollhole. Other then that all there. In South Dakota $125. I also have the rest of the smog parts if someone is interested.
The EGR tube between the fuel bowl and the throttle body is from the 75-78 timeframe. I think the code on the secondary diaphragm is for a 77 fed spec.
GLWS regardless. Might want to edit title tho.
@65swb45 you are correct. My father desmogged both the 40 and 60. Thank you for correcting that. This carb is from our 77 fj40. I also have the rest of smog parts if someone is looking.
do you know if it was early 77 or late 77? those carbs are almost SEASON specific in smog states like CALI, I spent almost a year searching for an early 77 carb a decade ago, trying to get my fj55 smogged. I gave up and updated to everything fj60 under the hood. If you dated that carb, you could target it to the right people looking for it. and there are people looking for it. not me, tho, anymore... GLWS!
The date code is stamped on the top of the carburetor, above the sight glass on the fuel bowl. What's it say?
Payment sent for carb.
