eleblanc:
It could be that you are using quality batteries. And perhaps, since my 4x4 alternator has a external cutout, it only charges to the required voltage when reved up.
I have been banging my head since long trying to find the cause of the drain. Eventually I traced it to the converter. The whole story is explained:
Battery, Alternator or its cutout? - IH8MUD.com Forum
The kill switch is a good idea but is good if you really do not want the truck for weeks.
And yes, even when there is no load, the draw remains in 0.2amp range. The reason being that a linear converter reduces 24 to 12 by dissipating heat (very inefficient). Now since say an IC like LM7812 (found in converters, if you hack one) has some quiescent current, which is low. BUT the transistor which boosts the current, located in front of LM7812 (generally speaking), is of higher rating and has a big quiescent current. While LM7812 might be rated 1amp of max load, a single transistor like 2N3055 is rated for 15amps max. And in a 6amp DC-DC 24-12 converter you will find 2 such transistors and one LM7812 (or its substitute). In a 10amp three transistor, 24amp seven transistor etc.
Be it 6amp, 10amp, 15amp 24amp (I have them all), idle draw (without any load) is above 0.2amps. Tested and verified by me. All of these converters were linear. If you have a switching converter, the story is different then.
Well, these are my views and I could be wrong.
