They are not showing what they should show that is I'm missing 24v.
Dimmer relay pooched? What does this relay do?
The relay switches connections inside the body of the relay and directs 12V and 24V to the correct wires in the low and high beam settings.
You're at the point that you either build your own system for 24V headlights, or you you really dig into your harness and try to make the stock setup work. Or at least find out where the issue is so you don't have a live wire deadheaded in the harness somewhere.
If you want to attempt to make the stock system work I would find the dimmer (headlamp) relay (try on the drivers side, around the steering column or footwell area, or in the left kickplate panel. Those would be my two guess's. Look for the number 85926 on it. Disconnect the relay. Check all the fuseable links on the 24V side at the battery for continuity. There should be a hot 24V and hot 12V lead coming into the relay. Check continuity of each wire from the connections to the headlight pin (will be the same color from the connection to the pins). If continuity is good on each wire, chances are it's in the relay.
If you go this path, please post your results (where the relay is, what color wires have the 24V and 12V inputs) etc so it is recorded for the next person who has to clean up their system.
I had a PO nightmare on my BJ42. Had to pull the headlight harness back to the firewall (thankfully not into the dash) to find where the PO cut and sliced. Repaired that, and the dimmer relay was ok, so it was relatively easy. Hopefully others will have some ideas that might lead right to where the problem is.
gb
