Hello all,
Step-dads 94 pick up 22re with 200+k on it is leaking a large amount of oil into the coolant system. We did a compression test and it seems that it is the #1 cylinder that has lost compression and all the rest are fine. My first inclination was that it HAD to be the head gasket failing near the coolant port and the cylinder wall in the first cylinder.
...but the more I read about the plastic guides wearing out and failing i began to wonder, could this cause a leak? or does all common sense point to head gasket?
Lots of info out there about replacing head gaskets on these so I won't bother with those q's... just wondering IF it could be anything else before I tear into what could be a properly working HG.
but you spoke of a compression problem in cylinder 1 as well which makes me shy away from this possibility.
