- Thread starter
- #21
Alrighty.
So, I finally got the crank case bolt off - I ended up having to buy a thicker 3' breaker bar, and use that in conjunction with my friend flooring the brakes
Finally 'BAM' the bolt came off \o/
So I got the head off, everything there actually looks fine. The gasket seemed to be fine, no cracks in the head that I've seen (as of yet)
So I take off the timing chain cover and... well, the guides were in pieces. The tensioner had been partially eaten through, there are tracks on the driver's side of the cover where the chain had started to eat through. I'm guessing the chain probably ate through something to allow coolant to drain into my oil pan.
Due to time issues I haven't been able to explore further lately, but my friend and I are doing a clean up/overhaul on it and will determine the cause of the leakage >.<
