2023+ Sequoia Dobinsons Suspension Options
crikeymike
ExitOffroad.com - Dobinsons Specialist
Supporting Vendor
Jacksonville Beach, Florida
Website
exitoffroad.com
Hey everyone, here's an evolving list of all the suspension parts Dobinsons is/will be offering for the new 2023 Sequoia 3rd Gen 4x4 Models. I'll edit and add as more parts come around.
Each part number is a hot link to take you right to the details of that specific part number.
Many items are in stock already, and the remaining first delivery is due in mid-March 2023.
Front Struts
IMS59-60446 - 2.6" Body, adjustable height monotube for 2-3" of lift
MRA59-A446 - 2.6" Body, 3-way adjustable valving (high and low speed compression and rebound adjustments), height adjustable monotube for 2-3" of lift
Rear Shocks
IMS59-60441 - 2.6" body for 1-3" of lift, monotube shocks
MRA59-A441 - 2.6" body for 1-3" of lift, 3-way adjustable valving (high and low speed compression and rebound adjustments) monotube shocks
Front Coils - Offered in Teal, Black and Red
TRD Pro models yield 1" less lift than listed below, since they come lifted already from the factory. These coils do not fit TRD Pro OE struts. 3" lift requires aftermarket UCA's
C59-834 - 3" lift with 0-110lbs added front end weight
C59-836 - 3" lift with 110-220lbs added front end weight
C59-838 - 4" lift with 0-110lbs added front end weight
C59-840 - 4" lift with 110-220lbs added front end weight
Rear Coils - Offered in Teal, Black and Red
C59-817V - Stock height with stock weight
C59-819V - 1" Lift with stock weight
C59-821V - 2" Lift with stock weight, 1" Lift with 220-440lbs added weight
C59-823V - 2" Lift with 220-440lbs added weight, 1" Lift with 600-800lb added weight
C59-851V - 3" Lift with stock weight, 2" Lift on a stock weight TRD PRO
C59-853V - 3" Lift with 440LBS added weight, 2" Lift with 220-440lbs on a TRD PRO
Front UCA's
UCA59-222K - Billet Aluminum, OE-style sealed ball joints for a maintenance free life, OE-style high quality rubber bushings for maximum NVH dampening and longevity, No greasing or maintenance required at all, completely noise-free operation, Adjustable on-vehicle for quick and easy alignment, Adjustable Camber and Caster for perfecting the vehicle’s handling
Front Strut Mounts
SC59-014 - OE replacement strut mounts, allows you to order your front suspension completely assembled prior to shipping, and not needing to disassemble the original coilovers, and no special tools needed (safer). Includes new bushings and hardware
Adjustable Rear Trailing Arms
These allow the rear pinion angle of the truck to be set properly once it has been lifted. They're also much beefier than stock
WA59-547K - Dobinsons Adjustable Rear Lower Control Arms for Sequoia 2023+ (also suits 200 and 300 series Land Cruiser)
WA59-571K - Dobinsons Adjustable Rear Upper Trailing Arms | Tundra 2022+ and Sequoia 2023+
Rear Panhard Rod (track bar)
This is recommend with a 2" lift or more. It allows you to re-center the rear axle under the frame
PR59-1421 - Adjustable length, new OE style rubber bushings already installed
Front Bump Stops
For those people who will be hitting it hard offroad, out in the desert, or wherever they may bottom out, a set of upgraded bump stops should be strongly considered
BS59-560 - Includes multiple height shims to set the bump stop gap accordingly
Front Lean Correction Spacer
This can be used to correct a lean in the truck by adding 1 to the low side (1/4" thick, adds 1/2" of lift), or add one to both sides to gain 1/2" lift on both sides
PS59-4032 - Spacer for 22+ Tundra and 23+ Sequoia
Rear Lean Correction Spacer
This can be used to correct a lean on one side, or add one to both sides to add 15mm more lift.
PS59-4035 - Rear 15mm Spacer for 22+ Tundra and 23+ Sequoia
Rear Sway Bar Links
SE59-591 - Adjustable length rear sway bar links for 1-4" of lift
Complete Lift Kit Builder Pages
These pages show all possible options on one page for you to build a complete kit, with either the IMS or the MRR shocks.
Dobinsons 2-3″ IMS 2023 Sequoia Lift Kit for 2023+
Dobinsons 2-3″ MRR 2023 Sequoia Lift Kit for 2023+
Added in the Billet adjustable UCA's and front strut mounts as well. No ETA on these, but they're coming thru production soon.
The MRA 3-Way adjustable shocks and struts have come into stock this week, finally.
IMS kit installed with 3" front and 2" rear lift and some fat tires.
