Builds 2018 GCC Spec 79 Series 1HD-FTE + H152 - The Camel (1 Viewer)
End of week progress pics, it’s been a wiring week. We are about 90% there on all the wiring now, 90% done and tested that is.
We had to order a new sending unit for the subtank (and an OEM subtank switch) since the sending unit from the LRA 100-series tank won’t work.
Cheers
AC compressor all worked out other than plumbing.
Rock Auto Denso compressor and HDJ79 clutch to work with the HDJ79 harmonic balancer.
Cheers
Getting things finished before we put the bed on.
Aluminum heat shield we built to protect the subtank transfer line from upcoming exhaust.
Subtank transfer pump plumbing, this is setup so that when the main tank is full it will shut off this pump automatically, or anytime via the switch.
Cheers
that heat shield looks like a OEM part, bravissimo
Where you rolled the edges that were trimmed by the shocks, what kind of tool do you use for that?
Great stuff!
Pliers, a hammer and a dolly. Chris who works for me did it.
Cheers
Over here, black duck are the seat covers you want
AC line work, compressor cap is for a Denso John Deer application.
Finalizing top mount IC.
Custom bumps being made to help with vibrations. They are actually 80-series hood bumps. 😉
EGT probe
Little details on our in house made rear bumper.
Cheers
