2010 lx570 driver door hinge
So I have wear in the door hinge (I think upper but might be lower too. When I grab the door in the bottom rear corner I can make it move up and down when applying force. Also makes a pop sound when this is happening. If I go over the right kind of bump I can hear it pop from that area. Door limiter check is OK it has been checked. Anyone replace the hinges or bushings on one of these? Looks like the part of the hinge that bolts to the body structure is going to be no picnic to get to the bolts. Is there alignment correction needed after changing the hinges. Here's a pic of the hinge
