Hello.
Yesterday the vehicle Revved up and immediately died. CEL and Battery light came on and there was no idle. Pressing ignition again the starter started cranking until I pressed ignition button again to stop it.
Looking around it seems like it could be the fuel pump ECU.
It's about $1000 for
89570-60150 Computer Assy, Fuel Pump Control, Toyota $235 @megazip (08-13 years only)
7702060342 TUBE ASSEMBLY, FUEL SUCTION WITH PUMP & GAGE $392 @NormReeves
77169-02050 Fuel Pump Assembly o-ring ~$7
77144-04010 Fuel Pump Retainer Ring ~$42
and $300 at my local shop
For some reason the 13+ fuel pump ECU is cheaper, more available and apparently doesn't fit the 08-13. I wonder what they changed.
I have half a tank of gas, the PCV valve is new, new starter and battery has plenty of juice to crank the starter.
I do not have techstream.
Should I just get these parts and hope for the best? Is this looking like a PM item for vehicles that didn't get a new pump in the recall?
Is now a good time to replace the rear suspension parts since the gas tank makes getting to the driver side 'shock' top bolt a PITA, and it would come out for the pump R&R?
What would you do?
Thanks
What would you do?
Thanks
