My 2 cents: if it was engineered I don’t think the engineering solution would have to create an unpredictable failure with a stress riser at an unnecessary angle. I think they just wanted a flat surface for labeling and didn’t appreciate the stress riser they were creating.
On my earlier Q, would building up the weak spot relieve stress or concentrate it somewhere else like in overdoing a weld in metal?
Agree completely on the reasons it fails. It is a bad design, and they in effect acknowledged this by updating the design on the later radiators.
As for if it would help prevent the crack.. it’s totally possible. In general I wouldn’t trust an epoxy to bond to the tank with anything approaching the tensile strength of the plastic itself. But then maybe it doesn’t have to. Maybe any level of assistance is enough to prevent the crack forming. But again, we just don’t know.
But, if it doesn’t work and a crack starts forming, the failure will be hidden from easy inspection and the only clue it isn’t working might be when coolant starts leaking. Without a patch you’d see the crack and have thousands of miles to plan the repair.
Edit: missed the part about redirecting the stresses. I think it would probably just spread it out effectively. Even if it didn’t, it would move the stress riser to a new spot that hadn’t been part of the bad design and over-stressed for all the miles the truck has driven so far.
