New to me, 2013, 132k miles. Removed the decorative radiator top this weekend and….no surprise.
SINCE NOT YET LEAKING, this is my < $15 attempt at “structural reinforcement”. Add a few shallow grooves near the crack edges (oriented with the low stress direction) to basically try and piss the crack off. Roughen up the surface with 180 grit paper (oriented with the high stress direction). Patch using JBWeld plastic. The red dash is the OEM radiator contour, whereas the blue dash is the contour I was going for.
As has been pointed out, the crack-before-leak indicates these cracks are initiated on the outside. To reduce the propagating stress, my only hope is to have enough strength from the patch in the radiator’s depth (short direction), which is why I was trying to maximize the patch size in that direction.
Lexus radiators typically fail in the plastic/aluminum joints at 150k-ish (see my signature before you ask me how I know!). Hopefully this repair will enable that type of failure instead.
