For Sale 2007 FJ Cruiser Massachusetts
2007 Toyota FJ Cruiser.
231,600 miles, automatic 4x4.
Clean title in hand.
VIN:JTEBU11F970007900
Located in Hopkinton, MA
Price: $9,800. No lowballers or trades. Only trade In would consider is trading cash for the vehicle.
Adult owned and maintained. I drive around 30-40k miles a year for work, so mainly highway miles. Always run synthetic oil, changed every 5k miles since I’ve owned it. Vehicle is in great shape with some minor scratches here and there, typical for a vehicle that’s 10 years old. No major imperfections. Typical surface rust but no rot on the underside. There was one spot I cut out and replaced on the frame because it was starting to look more than surface rust, otherwise it's solid. I have fluid filmed the frame/ underside prior to every winter since owning it. Truck runs and drives great, I have done a lot of preventative maintenance just due to age to keep the truck in near perfect mechanical shape. Drives nicely on the highway, and is just about unstoppable in the snow. Offroad it's
fantastic as well. Typically only wheeled around 3-4 times a year on Class 6 roads in NH.
Truck has part time 4x4 via manual shift knob, with A-trac and a locking rear differential, and Factory roof rack with crossbars. It also has rear parking sensors. Front weathertech floor mats are included, along the the factory rear cargo mat. Pictures show aftermarket stereo but the stock 6-disc FJ-Jammer stereo has been put back in. Everything functions as it should. Truck also has aftermarket LED fog lights wired to an OE foglight switch. The only thing the truck might need is the valve cover gaskets replaced some time in the future as they are starting to weep very slightly. This is a simple and cheap diy fix, I just have not had the time to do it. All 5 tires and rims are matching so you can do 5 tire rotations.
Despite higher mileage i would not hesitate to drive the truck across the country tomorrow. Last summer we took a road trip to South Carolina and back where it rolled over 200k miles on the way down there. I’ve gone through and replaced everything with bushings with new heavy duty aftermarket units besides the front lower control arms which were replaced with new OE toyota units. I've got a ton of aftermarket stuff i've already pulled off and am starting to part out. Can be included with the car for the right price.
Below is a list of the major preventative maintenance items I have done to the truck, theres likely more that im forgetting for forgot to add to my spreadsheet:
DateODODescription
9/5/2016150,230Rockmen Rear lower links
2/10/2017162,000Denso Radiator
Coolant flush
Toyota Pre-mixed Coolant
6/4/2017169,777new front Lower Control Arms
6/4/2017169,777Grease all cam adjusters
6/4/2017169,777front passenger caliper
6/4/2017169,777front brake pads
6/4/2017169,777brake fluid flush
6/4/17169,777Light Racing UCA
8/24/2017174,975Bilstein 6112 Front Coilovers
11/7/2017181,000new downstream o2 sensors and exhaust gaskets
11/7/2017181,000doug thorley y-pipe
11/8/2017181,100Resz fabrication rear upper links and panhard
11/15/2017181,500Replace Y-Pipe to Exhaust Flange
11/24/2017184,365Diode Dynamics LED revere lights, dome lights
4/4/2018191,451Bilstein 5160 Rear Shocks
4/14/2018192,200rear brake pads + rotors. adjust parking brake.
4/14/2018192,000Firestone MT2 tires installed
4/14/2018192,000New front and rear gas tank straps + hardware
4/18/2018192,250Replaced Alternator w/ Denso unit
4/18/2018192,250Battery
6/16/2018196,716Spark Plugs, Serpentine Belt
9/10/2018204,000front brakes, rotors, front drivers caliper, flush brakes
9/16/2018204,700front drivers hub/wheel bearing
6/5/2019226,350Charcoal Vapor Cannister
No trades, unless it’s for cash.
Bump. Corona virus special , $7,000
Just replaced the SPC ubj and inner/ outer tie rods. Get yourself the best Toyota IFS off-road vehicle ever made. Also drops panties*
*This statement not endorsed by the FDA.
