I have bought some sound deadening material and some deadening/insulation and some closed cell foam for the flat areas for spills and insulation.
If you know a lot about this I would like your thoughts, but here goes:
1. This Butyl stuff will go in the areas that are depressed for sound deadening. May try to put some on the ceiling, as well. Plan to cut strips that will fit in each area on all metal surfaces to include doors to help with the "ding" of sounds.
Amazon.com: Noico 80 mil 36 sqft car Sound deadening mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening: Automotive
Buy Noico 80 mil 36 sqft car Sound deadening mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening: Insulation & Noise Control - Amazon.com ✓ FREE DELIVERY possible on eligible purchasessmile.amazon.com
2. On vertical areas that don't have much risk of spills, etc, I will overlay this stuff:
Amazon.com: Thermo-Tec 14620 60" X 36" Heat and Sound Suppressor: Automotive
Buy Thermo-Tec 14620 60" X 36" Heat and Sound Suppressor: Insulation - Amazon.com ✓ FREE DELIVERY possible on eligible purchasessmile.amazon.com
3. I will then overlay this closed cell foam for insulation working from the middle of the floor out on all horizontal areas. Then lay the carpet back over the top.
Amazon.com: Noico Green 170 mil 36 sqft Сar Waterproof Sound Insulation, Heat and Cool Liner, Self-Adhesive Closed Cell PE Foam Deadening Material (1/6'' Thick Sound Deadener): Electronics
Buy Noico Green 170 mil 36 sqft Сar Waterproof Sound Insulation, Heat and Cool Liner, Self-Adhesive Closed Cell PE Foam Deadening Material (1/6'' Thick Sound Deadener): Insulation - Amazon.com ✓ FREE DELIVERY possible on eligible purchasessmile.amazon.com
Hoping to just use high quality duct tape to piece it all together.
Electrical:
I plan to run a 2 AWG power line under the truck to the bed of the truck for a 2nd battery, so don't have to worry about a BIG wire under the carpet, but . . .
I need to run maybe a 6-8 AWG to my arm rest and maybe another one to the front console from the rear wall of the cab.
Anything I need to worry about on the wiring? I was going to just put it inside a split loom.
Thanks!
6-8 ga to the armrest? You running some arm heaters or something in there? 8 AWG is rated to carry up to 30A 10' and 60A for 6AWG![]()
You should put the battery in the engine bay. I’m on your heels with the sound deadening And the rear seat delete.
Yes they doTundra's have a lot more room under the hood! Looks great @Comet
