Yes, agreed. However there aren't exactly huge swaths of 2005 LX engines around. A reputable dismantler nearby has a GX engine available.
It is very likely an overheated engine based on the fact that it came with a bottle of coolant to match the P0307 and P0308 codes measured pre purchase, however I was willing to take a chance based on price & condition other than engine.
It got worse when I got home and saw the coil packs were new, and that the codes stuck with 7 & 8 when swapping coil packs with known goods.
Plugs checked well on 1-7, but the plug was black and gooey on 8. Replacement on 8 didn't improve the situation.
Idle is lumpy and power is lacking. The lumpiness disappears at 1500+ rpm.
Engine warm compression check per the FSM is consistent across 1-6 at 215psi (a little higher than spec, but measured via a Harbor Freight gauge). 7 made 125 PSI, and 8 made 0 PSI.
I would prefer to do an engine swap rather than tear it down and do valve train and head gaskets (if that's all there is) especially as the donor motor is 125k vs 225k. The front of the motor (timing belt, WP, tensioners, seals, etc) service is part of baselining for either engine and much easier to complete with the engine on a stand as well. So there's a bit of a claw back on time there.
So back to my original query, what difficulties might I encounter using a 2004 GX470 donor? I understand the GX doesn't have heater T's, so there's a plumbing swap. Motor mounts? Oil Pan?
