2003 tacoma 3.4 throttle body
I just cleaned my throttle body this afternoon. I noticed when I went to open the butterfly to clean the around it there was play in shaft. I turned the shaft 1/4 to 1/2 inch the butterfly did not move. so at full throttle the butterfly was not totally flat. Is this normal?
Yes that us normal. It is fly by wire meaning that there is an accelerator position sensor which senses how far you are pressing the gas pedal and electronically opens the throttle. In case of a failure of the system there is a limp home mode which mechanically opens the throttle partially when you depress the gas pedal more than about halfway giving you just enough power to limp home. With no power to the system (key off) it is in the mechanical limp home mode and will only open the throttle partially. If you turn the key on and manually manipulate the throttle it will begin to open as soon as you turn it and will open all the way.
Hope that makes sense.
Sent from my iPhone using IH8MUD
Thanks it does. I wonder if it was fly by wire the fact it had a cable threw me off
