- Location
- United States
Looking to switch things up and move to an 80 series:
2003 Land Cruiser with 178k on the odo. Completely stock other than aux cord input installed by the PO.
Clean Title in my name.
LC is in very solid shape with only some minor cosmetic blemishes. No serious offroading at all. I'll try and cover everything as thoroughly as possible. Exterior 8/10, Interior 8/10.
I am the 4th owner, the first two lived in Brentwood, TN, serviced by Beaman Toyota where it lived the majority of its life. The gentleman I purchased it from owned it in Pensacola, FL and I have owned it since 2015 where it has lived in Hawaii for 2 years and now San Diego, CA for a little over 1.
The following is a gathering of CARFAX, PO notes/receipts, and maintenance that I have performed. The gentlemen I purchased it from was pretty ridiculous as he recorded every single gas station he filled up at. (I did not)
28k
Transmission Serviced
F/R Differentials serviced
Air Filter
Transfer Case Serviced
32k
New Antenna
Front Brakes Serviced
Oil Change
34k
Turn Front Rotors, new brake pads
New Tires
38k
Turn rear rotors, new pads
oil Change
64k
New Battery
New Serpentine Belt
New Transmission Hose
Tighten loose window regulator
89k
Timing belt
Thermostat
Water pump
F/R Diff oil replaced
117k
Rear bumper bracket adjusted
141,000
Upper Control Arm ball joint boots
Serpentine Belt
Hood Lift Struts
Headlight push pins
kick panel clips
Driver's side "foot rest" plastic
144k
Passenger Side Exhaust manifold and gasket replace
Spark plugs
New 3rd row seats
Roof rack remove and replace "gaskets"
Power Steering Fluid flush and replace
Wiper Blades x3
Rear Brake Caliper slide bolts replaced
151k
Pass side cv serviced and boots replaced
New subwoofer
New PCV
New Passenger side collector gasket
L/R wheel bearings
155k
Front/Rear differential oil serviced
New Windshield
New shifter bezel trim
New L/R Speaker Covers
163k
New Goodyear MTR Tires
4 wheel alignment
167k
New Battery
New front windshield wipers
176k
All 4 door lock actuators replaced.
Heater T's replaced
Rear Hatch Shocks replaced.
Air Filter
To install:
New Denso Radiator
New Gates Upper and Lower Radiator Hoses
Previous owner did say that the steering rack was replaced by the owner before him, but I don't have documentation/proof.
Timing belt due in 5k miles if following the 90K rule. NEW AISIN TIMING BELT KIT INCLUDED in the sale, to include water pump, oem thermostat, gasket etc.
Known Issues:
-There is a small amount of surface rust on the undercarriage from being in Hawaii. This is SURFACE Rust from the salt air. It was never driven in the ocean or any shenanigans from that. I purchased this Cruiser Rust free and it what is shown in the pictures is what developed in Hawaii. It was garaged for a year of the 2 years of ownership there. I'd be glad to do a video walk around of the any places you would be concerned about.
-Also in Hawaii, when renewing registration they ask my mileage and I didn't have the exact number so the worker said to estimate. My fault in agreeing to do so as the CARFAX shows a possible mistake in odometer reading. I pretty pissed about this as it is the only thing "wrong" on the CARFAX.
-The horn is intermittent. Haven't really tried to nail this one down.
-Driver's side original floor mat is showing a little wear.
I have all the mats which were taken out for pictures. It is not detailed in the pictures. I keep it clean all the time.
I also have the factory running boards in storage if wanted.
Looking for 11,500. OBO.
Call or text 615-542-3308
28k
Air Filter
32k
New Antenna
Oil Change
34k
New Tires
38k
oil Change
64k
New Battery
New Serpentine Belt
89k
Timing belt
Thermostat
Water pump
117k
141,000
Serpentine Belt
Hood Lift Struts
Headlight push pins
kick panel clips
144k
Spark plugs
New 3rd row seats
Wiper Blades x3
151k
New subwoofer
New PCV
L/R wheel bearings
155k
New Windshield
163k
4 wheel alignment
167k
New Battery
176k
Heater T's replaced
Air Filter
To install:
New Denso Radiator
Known Issues:
