To OP,
From my 98 manual with diff lock (page 108):
The rear differential lock system is pro- vided for use only when wheel spinning occurs in a ditch or on a slippery or ragged surface.
This differential lock system is effective in case one of the rear wheels is spinning.
First shift the four- wheel drive control into ”L” with the center differential locked to see if you can move forward. If this does not work, use the rear differential lock system also.
To lock the rear differential, push and turn the switch clockwise until it clicks.
Be sure to stop the wheels before locking the differentials.
For easy locking, turn the lock switch and gently depress the accelerator pedal.
The indicator light will blink when the switch is turned on. Wait a few seconds for the system to complete operation. Af- ter the differential is locked, the light will stop blinking and remain on.
The anti–lock brake system does not oper- ate when the rear differential is locked. It is normal operation for the ”ABS” warning light to be on at this time.
