Please Help
I was in my sons 2002 LC when at idle I got a flashing check engine light and followed by a rough idle. I drove it home which was only a 1/2 mile and could tell it had no power and the engine was missing. I popped open the hood and got a slight burning smell.
I pulled the error codes and came up with the following codes:
P0300 Random/Multiple misfire detected
P0301 Cylinder 1 Misfire detected
P0303 Cylinder 3 Misfire detected
P0306 Cylinder 6 Misfire detected
I did a ton of reading on here yesterday and narrowing it down to either the timing belt jumped or some kind of electrical problem. The misfires were on both banks and all at once so I am doubting it is the coil packs. Spark plugs have 10K on them and I changed out the fuel pump and filter out 2k miles ago.
It still runs but I am afraid to run it because I have read it is an interference motor and I would rather not damage any of the valves. I am not sure at this point how to easily verify the values are not damaged or the timing belt. I am sure it could use a timing belt/water pump kit and have read how to do it but I have limited indoor space to work on it and understand it could take a couple of days.
Does anyone have any thoughts what I should check or could it be something else?
I am probably going to tackle this myself and I am sure it is not within my budget but does anybody know the going rate to change the timing belt/water pump kit in the Dallas area? From what I have parts are $200 to $350
It has 203K miles on it and it has run great for the last 2 years that we have had it. Got it from the in-laws which have had it from when it was almost new and we were told they had done most if not all the recommend maintenance through the dealership and later through firestone both are out of state. Although I got the last minor maintenance records, they could remember what all had been done. My son has put very few miles on it.
Any help would be greatly appreciated
