Parting Out 2001 Land Cruiser 100 Series - Denver, CO
Do you have the navigation cd/dvd? Interested if you do
Driver's side mirror? If available and working (i don't care about paint) PM with price shipped to 95380.
What about dash pad and shifter handle? Thanks
Do you have drivers side rear trim piece the one that goes from rear fender well to just under tail light.also do you have driverside outer tail light.
front driver door glass? Shipped to 94102? Thanks!
No 1 timing belt cover? Shipped to 46375
I need the air filter box or at least the bottom half. Please PM
2001 Land Cruiser that I purchased for parts for 2 other 100 series. This LC was rolled in Dec 2016, but has run in my presence since then. 180k miles on it prior to the roll, no rust underneath. PM for specific prices/with an offer, or for more pics of something in particular. Located in Denver CO.
The body is either great or trash, depending on the panel. PM for specifics.
I also have all the tools required to pull things up to and including the engine. If you're local and want a discount for pulling the part yourself, you're more than welcome to use them.
Parts already gone/spoken for: Interior carpet, front seats, middle seats (I have a set of both but they are worn out/torn), console lid, steering wheel (still have airbag), driver door switch control panel, radio trim bezel, AC cluster, muffler/tailpipe, subwoofer, both front ABS sensors, front kick panel fuse box cover, pass front door panel (light & switch panel available), front and middle row seat belts, brake pedal pad, steering wheel, console, all remaining switch panels, rear vent window switches/wiring harness/motors, third brake light, rear window air deflector
Is the suroof
does it have the locking rear diff?
Is the complete sunroof assembly available?
Is the climate control and entire bezel still for grabs? I'm assuming it's the rotary dial controls? I would also want connectors and pigtials cut out to convert my '02 Nav to non Nav. Let me know please, thanks.
I need the right rear door outside mounding. Color code is 1C 3
