Mike6158 wrote:
Yep, that should work. The yellow hose is for adding the freon.
Yes, not that there is anything special about hose except it's color. More importantly the OP needs to know (if he doesn't already) that the center port on the manifold set is the service port. It is used for more than adding/charging the system. It also used to evacuate the system (of refrigerant) and when pulling a vacuum on the system prior charging. Some Manifolds have two service ports.
For some reason the hose sets don't usually come with a resealable can tap valve (don't see one in the pic either.
Pretty common. The manufacturers have no way of knowing what kind of can tap you need/prefer or if you are charging from a bulk tank, so they leave that up to you.
I'm very glad that you replied. Good points on the tap valve and gauges.
