200 Series Toyota Land Cruiser - Transfer Case Damper Torque Spec
Illinois
Hi to all of you,
I recently installed an ARB skit plate kit (5415100) in my 2008 Toyota Land Cruiser. I had to remove the Transfer Case dynamic damper as part of the installation. However, I am questioning the torque specification provided by ARB (see attached file - page 6 of 12) of 77Nm or ~57 lb-ft to be too high.
Does any of you know the recommended torque for the 2-M12 bolts holding the dynamic damper?
Thanks
Thank you Taco2Cruiser. That is a big difference!!!
Yeah it is!
I’ve replaced a few ARB skids with BB skids and found they all had broken harmonic balancer mounts. I thought it had more to do with the impact from bottoming out goes right into the cast aluminum case, which really doesn’t handle it too well. We seen a few cracked cases already from off road use. But now I know this is also to blame... sad really.
I’ve TIG’ed one case back together, but no need for that at all. I’ll call ARB and let them know.
9 ft lbf is barely hand tight. The cast aluminum the case is made of probably will start to deform at around 40-50, and sheer at around 70 based what I know of that material.
Yeah it is!
I’ve replaced a few ARB skids with BB skids and found they all had broken harmonic balancer mounts. I thought it had more to do with the impact from bottoming down goes right into the cast aluminum case, which really doesn’t handle it too well. We seen a few cracked cases already from off road us. But Now I know this is also to blame... sad really.
Indeed it is too high. I noticed that one of the bolts was starting to losing up at around 50 ft lbf. Now, I need to remove them and re-torque to 9 ftb using loctited and hope I did not mess up the transfer case or the damper.
ARB just e-mailed me a revised version of their instructions after I sent them an e-mail letting them know that the referenced torque may be too high. The recommended torque in their new version (3/09/2018 - exactly 2 years ago from today or the date of my e-mail) is 39Nm or 29 ft lbf. I have attached the revised instructions.
It’s deformed internally now. Cast aluminum just can’t handle that level of stress. I wouldn’t use loctite, it may push it over the edge when removing the balancer at a latter time, and you might crack the mount off. Best to just hand tighten it. (Seen this personably, it sucks)
9 ft lbf is too low for any torque wrench below $400 in my opinion. If you have a craftsman, anything from harbor freight, an Amazon cheaper wrench, they are all pretty inaccurate below 40.
My “engine work” wrench I use to do anything below 20, is an $1100 snap on. Every year it gets calibrated and that sometimes, even that has some trouble with that low of accuracy after a year of use on my personal motors.
I really wish I could find a good torque wrench in the 3-5nm range for carbon bike parts... I have probably 6 - click, digital and beam cheap to moderately expensive and I don't really trust any of them. Tested against each other is a range of at least 1nm. But then, I probably wouldn't put it in the race tool case. So beam for the durability (repeatability) at least. For the >=10ft/lbs higher end CDI click and digital. I'm not building engines though. Reminds me I'm overdue to get the big digital calibrated.
Instead of loc-tite, try vibratite. It does not harden. It stays soft and is reusable. It will not take as much heat as loc-tite though. Amazon carries it.
Try using an inch-pound wrench. 9 ftlbs = 108 inch lbs. Might be closer to mid range on an inch LB wrench.
Another PSA
Installing another pair of sliders and saw this while rolling around.
Looks like at one time this 200 had a transfer case fluid service and whoever put the dampener back on, didn’t see the cut out that goes around a bolt.
I’ll flip this around, but for anyone out there that may have had someone work around the t-case, it may be worth it to make sure the dampener is mounted properly.
The updated manual still is
this is still more than the factory recommended 9 ft lb. Isn't it going to deform the case?
@Taco2Cruiser , I recently installed the ski plates and used 29 ft lbs for damper (as stated in ARB guide) bolts as opposed to the factory recommended 9 ft lbs. Should I go back to 9 ft lbs or is the damage done?
I would.
Funny story. I've never seen that on my truck. It's a 2008, so the first year out of the chute in the US. Did they not ship the 200 with this Transfter, Dynamic Damper on all models, or is this a 'PO doing science' issue...again?
Parts diagrams show it being present with the earliest model year 200s, including yours. Someone probably needed a paper weight. I doubt you'd notice any difference with it in place.
Thanks for verification. Got impatient, found one online before I read this. Guess I will have to live with the extra 15hp and MPG improvement. Getting custom paint job on it, too.
Update: ordered, installed, test drove. Seven more MPG, women swooning, childrend instantly even smarter. Do recommend.
So I was changing my Tcase fluid, went under the car.... only to find that my 2008 don't have a damper either... hmmmm whos the Tcase bandit out there.
Seems to be #33183-60060. About $200. I mean dooooo I neeeeeed it??? Been driving like this for a while now. I sometimes have trouble getting into 4Lo, but that seem to be emission related (P0441/P0455) I thought changing the Tcase fluid may help, only to find a missing damper.
