SOLD #2 New Replica: FJ40 Rear Wiring Harness
GA Architect
Woodstock, GA
The OEM part number for this rear harness replication is #82420-90318B. This harness uses all 16ga wire and has an initial wrap of non-adhesive harness tape. The rear half has two extra protective layers; Tesa wire loom harness tape covered with a final wrap of gray electrical tape. Note, due to the rear tail light female plugs being no longer available, I've installed the Sumitomo 4 pin waterproof connectors. But you will have to swap the male connectors of the rear combination lights. The gray waterproof seal below is the same size as the OEM seal, so you wouldn't have to cut & crimp any of the existing combination lamp wires. Price $200
Note: I wired a special rear harness for my 1977 FJ40 for a 5 pin to 4 pin trailer harness. Thus I decided to build a couple extra following the OEM specs. I do have extra wire so I will be building two extras, but will use a couple of different wire colors to match the 1977 wiring diagram's wire color codes.
PM sent
Most Impressive .........:cool:
whats next rick ?
the Engine Bay
or
the under dash Cowl 🤔
i love the attn to period correct details ................
