1980 BJ41
2 battery / 24v system
Battery dimensions 8H x 7W x 10L (inches)
I've read every battery thread and I'm a bit over-saturated with info. I'm not winching, nor am I running extensive accessories. That said, cold weather performance is my main concern.
My goal is to find a quality mid-grade battery that won't cause any issues with the stock electrical system and fits the stock battery trays without modification.
I've read that some members prefer a marine starting battery for the 24v systems. Would this Deka be a safe option? Or is charging an issue with the stock setup?
Suggestions are of course welcome as well. Thanks up front.
Application: Marine
Cold Crank Amps (0 degrees F) (Amps): 800
Reference Crank Amps-32 degrees F (Amps): 1000
Voltage (Volts): 12
Maintenance-Free: Yes
Weight (lbs.): 44
Terminals: Left
Length (Inches) 10.75
Width (Inches) 6.75
Height (Inches) 9.375
Shop Deka 12-Volt 1,000-Amp Marine Battery at Lowes.com
Application: Marine
Voltage (Volts): 12
Weight (lbs.): 44
Terminals: Left
Width (Inches) 6.75
