do you have the EWD?
next step is to figure out witch one of the relays is cycling the compressor off.
[/QUOT]
Exact Wiring Diagram?
IF THE A/C AUTOMATIC AMPLIFIER DETECTS THE FOLLOWING CONDITIONS, IT STOPS THE AIR CONDITIONING.
THE TEMPERATURE AT THE AIR VENTS IS LOW.
* THERE IS A MARKED DIFFERENCE BETWEEN THE COMPRESSOR SPEED AND THE ENGINE SPEED.
* THE REFRIGERANT PRESSURE IS ABNORMALLY HIGH OR ABNORMALLY LOW.
* THE ENGINE SPEED DECREASES.
* RAPID ACCELERATION OCCURS.
From RavenTai:
Fro RavenTai:
also if the coolant gets too hot (as measured at the head) the compressor will be cut out by a realy,
there is a good old thread about this last one what just got bumped and is active right now.
From RavenTai:
yes there is a thermistor
Gieser said:UPDATE ON SITUATION:
Low is reading about 30 and High is reading about 220. What did you do to drop the pressure from 380 to 220?
FJ809496TLC= Low is reading about 30 and High is reading about 220. What did you do to drop the pressure from 380 to 220?
Gieser said:Okay, we have the issue of the air not getting cold enough (even though all parts replaced and flushed, etc. etc) which is really now a mystery except for the possibilites of it being the AMP, sensors or switches.![]()
We also have the problem of the A/C kicking on/then off, etc. This is not happening all the time, but sometimes. Still, when the compressor decides to run consistantly, it still cools at 65 degrees or 70 degrees, etc. When I start the car in really hot weather (like today), the compressor will not even kick on for a bit.![]()
Through diagnostics, we have excluded any blockage, any bad parts in the A/C line (Compressor, Clutch, receiver, expansion valve, evaporator, condenser), amount of freon, amount of air flow through condenser (fan clutch), heat valve, temp adjustment setting. The guages read fine and the temp of coolant is perfect.
To me, tis leaves a relay, a switch, a sensor, or something like that. What do you think?
From Tools R Us:
jumpering it to hot (12v +) so it stays on all of the time, then run a max A/C test. Be careful, you will have no safeties like hi pressure switch, best done with gauges hooked up and monitored.
by Tools R Us : You couldn't get power to the clutch? As soon as 12v is plugged in to the clutch lead it will snap closed and stay that way until unplugged?
by Tools R Us : Those pressures sound low and vent temps high, low on R134A? How much did you charge it with?
Gieser said:I disconnected the switch and ran a wire from the clutch side directly to the positive side of the battery and nothing happened (maye the connection was bad?).
Gieser said:They said they charged it with 28.somthing-or-another +-1.76oz. The guages were reading Lo 30 and Hi 225 early yesterday. I thought maybe they didn't charge it enough, but by what my guages say it could use a little more. The cycle between 58 and 61 is weird though.
