So you are saying I will be OK with just purchasing some springs and keeping the existing shocks etc and cranking my t-bars?... with a Slee rear bumper
That's something I did not consider. That may hold me over until I can do the suspension right.
I'm now considering just doing the Slee bumper with a single swingout and then the 866 rear springs (1.5'') since I only have 285/75/16 BFG's and need to be sure I can fit underground....
Then, a towards the end of the year adding the shocks, OME t-bars & diff drop. This will accomplish my main goal of being able to replace my stock hitch (I use it for hauling my Mtn bikes..) , get the spare tire up in air and allow for more clearance.
Thanks for all of the advice guys!
I've had the 865, 866 and now the Slee springs. Don't waste your time with the 866 and a heavy rear bumper.
Slee doesn't have tech info on these springs but after using them for 60 days ( wheeling, towing, DD) they appear to be superior to anything ARB is pushing.
jasonbraswell said:I've had the 865, 866 and now the Slee springs. Don't waste your time with the 866 and a heavy rear bumper.
3rd Cruiser said:Hey Craig,
I've got a set of 866 springs sitting in my garage. Pick up my camp table from Jonathan ,drive up to my place and they're yours. But don't forget the table![]()
sleeoffroad said:We have all the tech info on the SOF2RH springs since we designed them, however throwing out numbers to compare to OME is not going to do much. Essentially they are a heavy spring without the excessive height that you get with a OME863.
Richard, I appreciate the generous offer. I am not positive if I will do 866's or the Slee equivalent. If I decide on 866's then I will definitely take you up on your offer! What are you running for rear springs?
job. So my suggestion would be get the slee bumper, install my old springs and see how it rides. If you like the ride you are done, if not order the slee springs and re-install. Swapping springs is really no big deal.
